[GRASS-dev] grass 7.0 g.region segmentation fault
Markus Neteler neteler at osgeo.org
Wed Mar 4 07:42:41 EST 2009
On Tue, Mar 3, 2009 at 7:31 PM, Mohammed Rashad <rashadkm at gmail.com> wrote:
> grass70
> with new wxgui i selected location wizard on the startup screen
> 1. select coordinate system
> 2. choose projection --- ll(lat/long)
> 3. select ellipsoid ---- everst56
> 4. Summary
> after the location wizard when i click finish
> a message window appears with
> `Do you want to set the default region extents and resolution now?`
> if yes button was clicked..
> another message window displays
> `Error invlaid region`
> and a window appears
> when grass is restarted with new loacation created error apperas with
> title        : Error in g.region execution
> message : Unable to get current geographic extent. Force quiting wxGUI.
> Please run manually g.region to fix the problem
> when run g.region at command line
> as g.region -p
> error appers as
> segmentation fault
> But no problem reports for other types such as xy location, georeferenced
> files etc..
- when did you download GRASS? there have been modifications recently
  in this part
- which operating system are you using?
- if Linux, what does
   ldd `which g.region`
 say?
Markus
