[GRASS-dev] grass 7.0 g.region segmentation fault
Mohammed Rashad rashadkm at gmail.com
Wed Mar 4 09:51:05 EST 2009
> > grass70
> > with new wxgui i selected location wizard on the startup screen
> > 1. select coordinate system
> > 2. choose projection --- ll(lat/long)
> > 3. select ellipsoid ---- everst56
> > 4. Summary
> > after the location wizard when i click finish
> > a message window appears with
> > `Do you want to set the default region extents and resolution now?`
> > if yes button was clicked..
> > another message window displays
> > `Error invlaid region`
> > and a window appears
> > when grass is restarted with new loacation created error apperas with
> > title        : Error in g.region execution
> > message : Unable to get current geographic extent. Force quiting wxGUI.
> > Please run manually g.region to fix the problem
> > when run g.region at command line
> > as g.region -p
> > error appers as
> > segmentation fault
> > But no problem reports for other types such as xy location, georeferenced
> > files etc..
> - when did you download GRASS? there have been modifications recently
>  in this part
> - which operating system are you using?
> - if Linux, what does
>   ldd `which g.region`
>  say?
> Markus
I had downloaded grass from svn on February 10 and i am using ubuntu 8.10
GRASS 7.0.svn (loc11):~ > ldd `which g.region`
    linux-gate.so.1 =>  (0xb7f5e000)
    libgrass_vect.so => /usr/local/grass-7.0.svn/lib/libgrass_vect.so
(0xb7f06000)
    libgrass_dbmibase.so =>
/usr/local/grass-7.0.svn/lib/libgrass_dbmibase.so (0xb7ef6000)
    libgrass_gis.so => /usr/local/grass-7.0.svn/lib/libgrass_gis.so
(0xb7ea8000)
    libgrass_datetime.so =>
/usr/local/grass-7.0.svn/lib/libgrass_datetime.so (0xb7e9f000)
    libz.so.1 => /usr/lib/libz.so.1 (0xb7e77000)
    libgrass_dbmiclient.so =>
/usr/local/grass-7.0.svn/lib/libgrass_dbmiclient.so (0xb7e6d000)
    libgrass_dgl.so => /usr/local/grass-7.0.svn/lib/libgrass_dgl.so
(0xb7e55000)
    libgrass_dig2.so => /usr/local/grass-7.0.svn/lib/libgrass_dig2.so
(0xb7e40000)
    libgrass_rtree.so => /usr/local/grass-7.0.svn/lib/libgrass_rtree.so
(0xb7e39000)
    libgrass_linkm.so => /usr/local/grass-7.0.svn/lib/libgrass_linkm.so
(0xb7e36000)
    libgdal1.5.0.so.1 => /usr/lib/libgdal1.5.0.so.1 (0xb78c2000)
    libgrass_g3d.so => /usr/local/grass-7.0.svn/lib/libgrass_g3d.so
(0xb78a4000)
    libgrass_gproj.so => /usr/local/grass-7.0.svn/lib/libgrass_gproj.so
(0xb789a000)
    libproj.so.0 => /usr/lib/libproj.so.0 (0xb7868000)
    libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0xb7842000)
    libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb76e4000)
    libdl.so.2 => /lib/tls/i686/cmov/libdl.so.2 (0xb76e0000)
    libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0xb76cf000)
    libsqlite3.so.0 => /usr/lib/libsqlite3.so.0 (0xb765f000)
    libodbc.so.1 => /usr/lib/libodbc.so.1 (0xb75f8000)
    libodbcinst.so.1 => /usr/lib/libodbcinst.so.1 (0xb75eb000)
    libexpat.so.1 => /usr/lib/libexpat.so.1 (0xb75c4000)
    libxerces-c.so.28 => /usr/lib/libxerces-c.so.28 (0xb720a000)
    libjasper.so.1 => /usr/lib/libjasper.so.1 (0xb71bb000)
    libhdf5-1.6.6.so.0 => /usr/lib/libhdf5-1.6.6.so.0 (0xb7089000)
    libmfhdf.so.4 => /usr/lib/libmfhdf.so.4 (0xb7064000)
    libdf.so.4 => /usr/lib/libdf.so.4 (0xb6fbd000)
    libogdi.so.3.2 => /usr/lib/libogdi.so.3.2 (0xb6f9f000)
    libgif.so.4 => /usr/lib/libgif.so.4 (0xb6f97000)
    libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0xb6f76000)
    libtiff.so.4 => /usr/lib/libtiff.so.4 (0xb6f21000)
    libpng12.so.0 => /usr/lib/libpng12.so.0 (0xb6efb000)
    libnetcdf.so.4 => /usr/lib/libnetcdf.so.4 (0xb6eca000)
    libpq.so.5 => /usr/lib/libpq.so.5 (0xb6ea9000)
    libpthread.so.0 => /lib/tls/i686/cmov/libpthread.so.0 (0xb6e90000)
    librt.so.1 => /lib/tls/i686/cmov/librt.so.1 (0xb6e86000)
    libcurl-gnutls.so.4 => /usr/lib/libcurl-gnutls.so.4 (0xb6e4b000)
    libmysqlclient.so.15 => /usr/lib/libmysqlclient.so.15 (0xb6c68000)
    libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xb6b79000)
    libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb6b6a000)
    /lib/ld-linux.so.2 (0xb7f44000)
    libgeos-3.0.0.so => /usr/lib/libgeos-3.0.0.so (0xb6a3f000)
    libltdl.so.7 => /usr/lib/libltdl.so.7 (0xb6a36000)
    libicuuc.so.38 => /usr/lib/libicuuc.so.38 (0xb690e000)
    libicudata.so.38 => /usr/lib/libicudata.so.38 (0xb5e37000)
    libssl.so.0.9.8 => /usr/lib/i686/cmov/libssl.so.0.9.8 (0xb5df1000)
    libcrypto.so.0.9.8 => /usr/lib/i686/cmov/libcrypto.so.0.9.8 (0xb5ca5000)
    libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0xb5c13000)
    libcom_err.so.2 => /lib/libcom_err.so.2 (0xb5c0f000)
    libgssapi_krb5.so.2 => /usr/lib/libgssapi_krb5.so.2 (0xb5be5000)
    libcrypt.so.1 => /lib/tls/i686/cmov/libcrypt.so.1 (0xb5bb3000)
    libldap_r-2.4.so.2 => /usr/lib/libldap_r-2.4.so.2 (0xb5b70000)
    libidn.so.11 => /usr/lib/libidn.so.11 (0xb5b3e000)
    libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0xb5b1a000)
    libgnutls.so.26 => /usr/lib/libgnutls.so.26 (0xb5a7d000)
    libtasn1.so.3 => /usr/lib/libtasn1.so.3 (0xb5a6b000)
    libgcrypt.so.11 => /lib/libgcrypt.so.11 (0xb5a02000)
    libnsl.so.1 => /lib/tls/i686/cmov/libnsl.so.1 (0xb59e8000)
    libkrb5support.so.0 => /usr/lib/libkrb5support.so.0 (0xb59df000)
    libkeyutils.so.1 => /lib/libkeyutils.so.1 (0xb59db000)
    libresolv.so.2 => /lib/tls/i686/cmov/libresolv.so.2 (0xb59c7000)
    liblber-2.4.so.2 => /usr/lib/liblber-2.4.so.2 (0xb59b9000)
    libsasl2.so.2 => /usr/lib/libsasl2.so.2 (0xb59a0000)
    libgpg-error.so.0 => /lib/libgpg-error.so.0 (0xb599c000)
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090304/59ca6d05/attachment-0001.html
