[GRASS-dev] Re: [GRASS GIS] #224: cache bug in DGLib
GRASS GIS trac at osgeo.org
Wed Mar 4 12:46:35 EST 2009
  Reporter:  martinl  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.4.0
 Component:  Vector   |     Version:  svn-develbranch6
Resolution:           |    Keywords:  vector, dglib, cache
  Platform:  All      |         Cpu:  All
Comment (by mmetz):
 Replying to [comment:6 mlennert]:
 > Replying to [comment:4 mmetz]:
 > > dglib cache back to life in trunk r36113 and devbr6 r36114
 > > testing is very welcome!
 > Still need to look at the actual results more in detail (look good at
 rough glance). Also ran a few v.net.path's and everything seems fine.
 The critical values are the costs returned by Vect_net_shortest_path(). I
 did my testing by inserting
 fprintf(stdout, "%f\n", cost);
 e.g. in v.net.iso/main.c line 254 and v.net.alloc/main.c line 214
 then with cache enabled: v.net.iso >costs.cache, similar for cache
 disabled
 I have added comments in lib/vector/Vlib/net.c explaining how to
 disable/enable the cache. The comments and relevant code are in lines 489
 - 504. Note that there is no need to comment out line 436.
 > Concerning BUG2: Maybe we could think of some test cases ?
 For BUG1, I created a test vector as described in dglib/BUGS. It should
 not be too difficult to create a test vector for BUG2, but unfortunately I
 have not the faintest idea where to start poking around in dglib. I really
 tried to understand where and how the arcs are inserted, and by now I
 think I'm not that bad in understanding source code, but this is beyond
 me. You're welcome to get your hands dirty with dglib yourself:-)
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/224#comment:7>
