[GRASS-dev] Compile errors - dllmain and fmode - releasebranch_6_4 and develbranch_6
Markus Neteler neteler at osgeo.org
Thu Mar 5 14:40:57 EST 2009
Devs,
Colin tried attached patch and with that DATETIME builds
but then the problem continues for the other libraries.
I am no good at reading Makefiles, help needed.
Markus
On Thu, Mar 5, 2009 at 5:24 PM, Colin Nielsen <colin.nielsen at gmail.com> wrote:
> Still not working, sorry. I'm still a bit new at this so I'll give you
> my steps to make sure I didn't miss anything
> 1) svn up
> 2) make clean
> 3) config.status --recheck
> 4) make
> Result:
> $ make > /dev/null
> gcc.exe: ../../lib/gis/OBJ.i686-pc-mingw32/dllmain.o: No such file or directory
> make[3]: *** [/usr/local/src/grass6_devel/dist.i686-pc-mingw32/lib/libgrass_datetime.6.5.svn.dll]
> Error 1
> make[3]: *** No rule to make target
> `../../lib/gis/OBJ.i686-pc-mingw32/dllmain.o', needed by `default'.
> Stop.
> make[3]: *** [/usr/local/src/grass6_devel/dist.i686-pc-mingw32/lib/libgrass_gmath.6.5.svn.dll]
> Error 1
> make[3]: *** [/usr/local/src/grass6_devel/dist.i686-pc-mingw32/lib/libgrass_linkm.6.5.svn.dll]
> Error 1
> make[3]: *** [/usr/local/src/grass6_devel/dist.i686-pc-mingw32/lib/libgrass_driver.6.5.svn.dll]
> Error 1
> make[3]: *** [/usr/local/src/grass6_devel/dist.i686-pc-mingw32/lib/libgrass_pngdriver.6.5.svn.dll]
> Error 1
> There were many more errors in lib, db, display, vector, raster, etc.
> I'll keep being the mingw/msys test bed if you propose other possible
> solutions.
> -Colin
> On Wed, Mar 4, 2009 at 4:57 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Wed, Mar 4, 2009 at 5:47 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
>>> Markus Neteler wrote:
>>>> >> >> The fixes were
>>>> >> >> - 6.4.svn  (r35767, r35769)
>>>> >> >> - 6.4.0svn (r35768, r35770)
>>>> >> >> > [Probably because a complete fix doesn't exist; the change implies
>>>> >> >> > that dllmain.c would be part of lib/gis, but lib/datetime is built
>>>> >> >> > first.]
>>>> >> >> What is exactly missing?
>>>> >> > dllmain.c.
>>>> >> > But hang on: DLLMAIN_OBJ doesn't appear to be defined anywhere in
>>>> >> > develbranch_6.
>>>> >> I seem to have a different version:
>>>> > Er, right; my Shlib.make was modified to remove the DLLMAIN_OBJ stuff
>>>> > (probably to get it to compile).
>>> Actually, that's probably not it. But for whatever reason, I have a
>>> modified version without the changes.
>> Here is what's in SVN:
>> http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/include/Make/Shlib.make
>> http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/lib/gis/Makefile
>> Ha!
>> No trace of dllmain.c in
>> I'm confused. Perhaps our radio-bridge based internet connection in the
>> office failed silently. Submitted (again) in r36196 for devel_branch6.
>> In 6.4.0svn it was already present.
>>>> On which platform did it fail?
>>> It will fail on MinGW, as the changes add dllmain.o to the link
>>> command but don't provide any way for that file to be created.
>> Please give the compilation another try.
>> Colin, too...
>> The entire change is yet missing in grass 7 as I don't know
>> how to modify the Makefiles appropriately. The patches of
>> the trac ticket won't work.
>> Markus
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090305/be92d6cc/mingw.obj
