[GRASS-dev] [GRASS GIS] #518: negative flow accumulation with r.watershed SFD or MFD
GRASS GIS trac at osgeo.org
Thu Mar 5 14:49:13 EST 2009
 Reporter:  dylan        |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:
Component:  default      |     Version:  svn-develbranch6
 Keywords:  r.watershed  |    Platform:  Linux
      Cpu:  x86-32       |
 I just noticed that there are negative flow accumulation numbers in the
 output from the recently updated r.watershed. I am working with today's
 SVN (develbranch_6). Here is an example from the spearfish dataset:
 g.region rast=elevation.10m
 r.watershed --o -f elevation=elevation.10m accumulation=acc
 r.info acc
 # SFD:
 Range of data:    min = -811721.000000  max = 735505.000000
 # MFD:
 Range of data:    min = -641132.649622  max = 720490.193602
 This looks like an overflow problem...but I cannot seem to find anything
 obvious in the code.
Ticket URL: <http://trac.osgeo.org/grass/ticket/518>
