sqlite and grass65: was Re: [GRASS-dev] sqlite and grass64
Michael Barton michael.barton at asu.edu
Thu Mar 5 20:27:58 EST 2009
On Mar 5, 2009, at 5:44 PM, <grass-dev-request at lists.osgeo.org> wrote:
> Date: Thu, 5 Mar 2009 16:24:38 -0800
> From: "Moskovitz, Bob" <Bob.Moskovitz at conservation.ca.gov>
> Subject: RE: sqlite and grass65: was Re: [GRASS-dev] sqlite and
> 	grass64
> To: "Markus Neteler" <neteler at osgeo.org>,	"Moritz Lennert"
> 	<mlennert at club.worldonline.be>
> Cc: GRASS developers list <grass-dev at lists.osgeo.org>
> Message-ID:
> 	<A73B6E7A4503E948826CE81A65AF5FECA2A569 at docexs1.ad.consrv.ca.gov>
> Content-Type: text/plain;	charset="iso-8859-1"
>>> Concerning the need to be able to easily backup/share, I
>> think we definitely
>>> need some module which isolates and exports a series of
>> chosen maps in a new
>>> temporary mapset with a local sqlite db file, copies the
>> chosen maps into
>>> this temp mapset and then creates a tarball (or zip or
>> whatever) with the
>>> basic LOCATION info (i.e. a PERMANENT mapset with PROJ and
>> WIND files) and
>>> the temp mapset. Shouldn't be too hard to wip up, or ?
>> Essentially a v.pack/v.unpack, right?
>> Markus
> What would be really neat is if there was a way to delete, as well
> as archive a location from the startup screen.
> Bob
You can delete or rename a location or a mapset from the wxPython
startup screen.
Michael
