[GRASS-dev] r.terraflow on windows grass6.4 RC2 (osgeo4w)
massimo di stefano
massimodisasha at yahoo.it
Fri Mar 6 18:07:28 EST 2009
Apologize crossposting, i wrote these mail to the user list,
maybe better here on the dev too.
i'm tring to use grass on windows (osgeo4w.exe installer)
but "r.terraflow" give me some prblems
on the spearfish dataset :
r.terraflow.short elevation=elevation.10m a PERMANENT
filled=elevation10m.filled direction=elevation10m.direction
swatershed=elevation10m.watershed accumulation=elevation10m.accu
tci=elevation10m.tci d8cut=infinity memory=300 STREAM_DIR=C:\tmp
stats=stats3.out
MFD flow direction
D8CUT=999999986991104.000000
Memory size: 300.00M (314572800) bytes
Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
raster elevation.10m is of type DCELL_TYPE --precision may be lost.
STREAM temporary files in /var/tmp (THESE INTERMEDIATE STREAMS WILL
NOT BE DELETED IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM. TO SAVE
SPACE PLEASE DELETE THESE FILES MANUALLY!)
file stats3.out exists - renaming.
ami_single_temp_name: mkstemp failed: : No such file or directory
Assertion failed: 0, file ami_stream.cc, line 75
This application has requested the Runtime to terminate it in an
unusual way.
Please contact the application's support team for more information.
in the file stats3.out i have :
Free Memory=-1
[0.0] Thu Mar 05 23:22:40 2009
Command Line:
C:\OSGeo4W\apps\grass\grass-6.4.0RC3\bin\r.terraflow.short.exe
elevation=elevation.10m a PERMANENT filled=elevation10m.filled
direction=elevation10m.direction swatershed=elevation10m.watershed
accumulation=elevation10m.accu tci=elevation10m.tci d8cut=infinity
memory=300 STREAM_DIR= mp stats=stats3.out
input elevation grid: elevation.10m
output (flooded) elevations grid: elevation10m.filled
output directions grid: elevation10m.direction
output sinkwatershed grid: elevation10m.watershed
output accumulation grid: elevation10m.accu
output tci grid: elevation10m.tci
[0.0] MFD flow direction
[0.0] D8CUT=999999986991104.000000
[0.0] Memory size: 300.00M (314572800) bytes
region size = 2.53M (2654802) elts (1398 rows x 1899 cols)
internal nodata value: -9999
it don't produce any output (onlt the stats file) and terminate
immediatly
have you any idea ?
i manually created the directory tmp in C:
p.s.
is these an osgeo4w probles?
do you know any grass-windos version that has r.terraflow working?
i'm really new to windos (never used it) ... so maybe i'm doing
something wrong :-/
i'm tring to make a foss-gis migration at university (idrology)
so i need a bit of time to port all the people on linux :-/
.... where r.terraflow works great and with really good results!
thanks to All,
Massimo Di Stefano
massimodisasha a yahoo.it
epifanio on irc.freenode.net /join gfoss
Massimo Di Stefano
Un allegato HTML è stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090307/6b0397fa/attachment.html
