[GRASS-dev] running v.surf.rst from GUI
Martin Landa landa.martin at gmail.com
Sun Mar 8 09:07:42 EDT 2009
2009/3/8 Helena Mitasova <hmitaso at unity.ncsu.edu>:
> 1. It is really hard to find where to put the  name of the main output
> "elevation"
>  - it is not under tab "outputs" but it is under tab "optional" which has
> several inputs
> that you actually must define if you don't want to end up interpolating
> category
> numbers. The tab optional isn't visible, so you need to click on the arrow
> to get to it.
> I think the elevation should be under outputs
indeed, I am trying to keep all parameters in four tabs (which are
visible by default). I don't feel familiar with v.surf.rst. Could you
suggest reordering parameters to less tabs?
> 2. I was unable to change the layer number - it was stuck at 1 (this may be
> problem
> with my installation or I am not clicking on it the right way?, typing it
> in, deleting it did not
> work either), so there was no way
> to interpolate the z-coordinate. I think that the layer number should be
It was a bug, fixed in r36250 (devbr6) and r36251 (relbr64).
> P.S. Any chance for changing default layer to 0 at least in grass7,
> to make it possible to run just v.surf.rst mypoints elev=myelev  ?
> Without defining layer, it is set to 1 and category number is interpolated
> by default if column is not defined - particularly unpleasant surprise
> after running a longer computation. Layer number and column name can then be
> under optional. I can make the change in grass7 if there are no objections
> to see whether it will cause any problems.
I would suggest to replace in all modules which uses 'layer=0' with
appropriate flag.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
