[GRASS-dev] location wizard borked
Michael Barton michael.barton at asu.edu
Mon Mar 9 17:40:26 EDT 2009
Choosing coordinates. Page after I pick UTM. The pulldown for zone is
misformatted and crammed at the top, and inaccessible.
2nd problem. Using EPSG code, after picking the code, there is a popup
that asks which projection to use. It is supposed to have the number,
followed by a description. Only the number is showing and not the
description. So there is no way to tell which number to pick.
3rd problem (not location wizard).
Also, the multifile import dialogs don't work on the Mac. Just
discovered that too.
This is because the wx.StaticBox is defined (in __dolayout) AFTER the
contents of the static box. wx.StaticBox MUST be defined BEFORE any of
its contents, or no controls work inside on the Mac. Because this is
currently in a separate method called after everything else in the
dialog, it has to be reconfigured. I might be able to work on it
tonight.
This probably is affecting the Location Wizard too, but I can't get
far enough to find out.
I didn't know that any recent changes had left these inoperable as I
have not had to create a location in awhile or had to import a dxf file.
Michael
On Mar 9, 2009, at 2:18 PM, Markus Neteler wrote:
> Michael
> On Mon, Mar 9, 2009 at 10:05 PM, Michael Barton <michael.barton at asu.edu
> > wrote:
>> Martin, et al.
>> Something has messed the location wizard. Formatting is problematic
>> so that
>> you can't get the pull downs for utm zone.
> In which subdialog is that precisely? Just for easier testing...
> Markus
>> I'm not sure what else is
>> happening, but wanted to get this out there ASAP because of the
>> immanent 6.4
>> release.
>> Michael
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
