[GRASS-dev] location wizard borked
Vincent Bain bain at toraval.fr
Tue Mar 10 03:24:40 EDT 2009
Hello all,
related to the location wizard, perhaps what follows does not deal with
any sort of bug but my misuse of the location creation process :
If you need to create from scratch a new gisdabe, located elsewhere than
the current one, the location wizard first writes your new location
directory in the /current/ gisdbase instead of the new one you've just
set. Then when you define a new mapset or want to start from within
PERMANENT, the application fails, with this message :
        Starting GRASS ...
          File "/usr/local/grass-6.4.0svn/etc/wxpython/gis_set.py", line
        401, in OnWizard
        self.lblocations.SetSelection(self.listOfLocations.index(gWizard.location))
        ValueError: list.index(x): x not in list
        686, in OnStart
            "set=LOCATION_NAME=%s" %
        self.listOfLocations[self.lblocations.GetSelection()]])
        IndexError: list index out of range
(tested recently on grass6.4.0 (rev 36255))
Am I doing somenthing wrong ?
Formerly with tcltk it would work (so when in this case, I start from
tcltk...)
Yours,
Vincent.
Le lundi 09 mars 2009 à 14:40 -0700, Michael Barton a écrit :
> Choosing coordinates. Page after I pick UTM. The pulldown for zone is
> misformatted and crammed at the top, and inaccessible.
> 2nd problem. Using EPSG code, after picking the code, there is a popup
> that asks which projection to use. It is supposed to have the number,
> followed by a description. Only the number is showing and not the
> description. So there is no way to tell which number to pick.
> 3rd problem (not location wizard).
> Also, the multifile import dialogs don't work on the Mac. Just
> discovered that too.
> This is because the wx.StaticBox is defined (in __dolayout) AFTER the
> contents of the static box. wx.StaticBox MUST be defined BEFORE any of
> its contents, or no controls work inside on the Mac. Because this is
> currently in a separate method called after everything else in the
> dialog, it has to be reconfigured. I might be able to work on it
> tonight.
> This probably is affecting the Location Wizard too, but I can't get
> far enough to find out.
> I didn't know that any recent changes had left these inoperable as I
> have not had to create a location in awhile or had to import a dxf file.
> Michael
> On Mar 9, 2009, at 2:18 PM, Markus Neteler wrote:
> > Michael
> > On Mon, Mar 9, 2009 at 10:05 PM, Michael Barton <michael.barton at asu.edu
> > > wrote:
> >> Martin, et al.
> >> Something has messed the location wizard. Formatting is problematic
> >> so that
> >> you can't get the pull downs for utm zone.
> > In which subdialog is that precisely? Just for easier testing...
> > Markus
> >> I'm not sure what else is
> >> happening, but wanted to get this out there ASAP because of the
> >> immanent 6.4
> >> release.
> >> Michael
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
