[GRASS-dev] v.type.sh question - important for 6.4 release
Michael Barton
michael.barton at asu.edu
Wed Mar 11 11:50:58 EDT 2009
On Mar 11, 2009, at 4:23 AM, Glynn Clements wrote:
> Michael Barton wrote:
>> Because the way that v.type works makes it unusable in a GUI, Hamish
>> wrote a script wrapper that DOES work in the GUI. Logically, it is
>> placed in $GISBASE/etc/gui/scripts.
>> However, windows cannot execute it there. I'm not sure if it is
>> because it needs to have a *.exe put on the end or because it DOES
>> have a *.exe and the GUI doesn't reference it correctly. I'm not sure
>> if it just needs to be renamed (i.e., drop the .sh), or moved to the
>> main $GISBASE/script directory, or what. But I bet that it is pretty
>> easy to fix this for windows. I just don't know what to do.
>> If someone could offer advice, I could get it working for the 6.4
>> release.
> The way that we normally make shell scripts work on Windows is to
> provide a .bat file which explicitly invokes the script via $GRASS_SH.
> On Windows, the $GISBASE/bin directory will contain a .bat file for
> each script in the $GISBASE/scripts directory. These are created using
> the scripts/windows_launch.bat file as a template.
> It may suffice to add $GISBASE/etc/gui/scripts/v.type.sh.bat. If that
> doesn't work, add an "if windows ..." case to gis.m's "execute"
> function, which invokes the script via $env(GRASS_SH).
> Glynn Clements <glynn at gclements.plus.com>
This sounds good. Two questions.
1) How can we get the *.bat files to be generated for files in the
$GISBASE/ext/gui/scripts folder?
2) Can v.type.sh.bat be called by just specifying v.type.sh? Or do you
need to fully specify the *.bat extension?
Thanks
Michael
