[GRASS-dev] Re: [GRASS GIS] #399: Added "backlink" functionality to r.walk, r.cost & r.drain
GRASS GIS trac at osgeo.org
Thu Mar 12 14:08:05 EDT 2009
  Reporter:  cnielsen     |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  major        |   Milestone:  6.4.0
 Component:  Raster       |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  All          |         Cpu:  All
Comment (by dylan):
 Just re-compiled GRASS with Colin's recent patches to r.cost, r.drain, and
 r.walk. Compiles fine against develbranch_6 on linux, with visibly
 different results. Using the output direction update to r.cost/r.drain
 does not appear to differ much from the original implementation. The
 results from r.walk/r.drain using the output direction patch results in
 considerably differences-- that appear to be non-optimal in this terrain.
 Code and resulting output posted here:
 http://casoilresource.lawr.ucdavis.edu/drupal/node/544#comment-948
 Thanks for the work on these modules. I wonder if using more than the
 cardinal directions would result in a more realistic "direction map".
Ticket URL: <http://trac.osgeo.org/grass/ticket/399#comment:19>
