[GRASS-dev] running v.surf.rst from GUI
Markus Neteler neteler at osgeo.org
Fri Mar 13 04:50:53 EDT 2009
On Fri, Mar 13, 2009 at 8:55 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2009/3/13 Helena Mitasova <hmitaso at unity.ncsu.edu>:
>> Inputs   Outputs   Parameters
>> and Markus is right - guisection is missing for elev, it should be added
>> here
>> 189     parm.elev->description = _("Output surface raster map (elevation)");
>> parm.elev->guisection = _("Output_options");
>> and for maskmap as well (that should be under Inputs tab)
>> If you could change this it would be great (I won't have time until weekend
>> to
>> do something about it)
> done in GRASS 7 (r36353). In no objections I will backported it to
> devbr6/relbr64.
Great job, Martin! Looks much better now.
Thanks also for the "clean" Cmd> button.
Markus
