[GRASS-dev] Re: [GRASS GIS] #528: wxGUI cmd: r.mapcalc fails
GRASS GIS trac at osgeo.org
Fri Mar 13 17:07:04 EDT 2009
  Reporter:  neteler   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by cmbarton):
 I'm not sure we're talking about exactly the same thing.
 Currently the very simple command processor does not require quotes around
 the main r.mapcalc argument. This is also the case in other settings,
 including the TclTk command processor. Quotes are not required around the
 main r.mapcalc argument in the terminal on my Mac either. That was the
 original issue. I don't see this, in and of itself as a defect--though I
 suppose others might disagree.
 Spaces, in and of themselves are not a problem in the command processor.
 The following works fine, for example
 r.mapcalc newmap = 5
 Note the lack of quotes and the spaces on either side of the "=".
 I think the command processor also allows strings with spaces surrounded
 by quotes within arguments if a command requires them, but I would need to
 test this on a particular set of cases. I currently can't think of an
 appropriate test, but I'm sure there are such cases. If it does not allow
 spaces within an argument (as allowed by a GRASS command), this does need
 to be fixed if possible so that any GRASS command can be parsed correctly.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/528#comment:10>
