[GRASS-dev] Re: [GRASS GIS] #523: wxGUI: querying a vector map in edit mode does nothing
GRASS GIS trac at osgeo.org
Sat Mar 14 10:30:42 EDT 2009
  Reporter:  msieczka  |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Changes (by martinl):
  * status:  new => assigned
  * owner:  grass-dev at lists.osgeo.org => martinl
 * cc: grass-dev at lists.osgeo.org (added)
Comment:
 Replying to [comment:3 msieczka]:
 > Seems translation-related issue. I can reproduce it for any vector map,
 but *only in Polish translation*. After "export LC_ALL=C" works fine.
 yes, it's problem with v.what. Temporally fixed in r36378. v.what should
 have script-style output which is not based on used locales.
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:6>
