[GRASS-dev] Re: [GRASS GIS] #523: wxGUI: querying a vector map in edit mode does nothing
GRASS GIS trac at osgeo.org
Sat Mar 14 19:46:27 EDT 2009
  Reporter:  msieczka  |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by glynn):
 Replying to [comment:6 martinl]:
 > > Seems translation-related issue. I can reproduce it for any vector
 map, but *only in Polish translation*. After "export LC_ALL=C" works fine.
 > yes, it's problem with v.what. Temporally fixed in r36378.
 Not really; see comment:9. It also needs to set LC_MESSAGES.
 BTW, the GUI should leave os.environ alone; pass env=... to Popen() to
 control the environment for child processes.
 > v.what should have script-style output which is not based on used
 locales.
 Agreed. Setting LC_MESSAGES is overkill (LC_ALL more so), as it will also
 affect error messages meant for the user.
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:10>
