[GRASS-dev] Re: [GRASS GIS] #536: memory corruption
GRASS GIS trac at osgeo.org
Thu Mar 19 15:39:44 EDT 2009
  Reporter:  martinl  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  blocker  |   Milestone:  7.0.0
 Component:  Vector   |     Version:  svn-trunk
Resolution:           |    Keywords:
  Platform:  Linux    |         Cpu:  x86-32
Comment (by mmetz):
 Replying to [comment:2 martinl]:
 > Replying to [comment:1 mmetz]:
 > > If you svn upped recently, and did not make distclean, this could be
 the reason, because I have added LFS support to vector libs. The latest
 grass7 is in constant use by me, no segfault, all vector operations work.
 Please let me know if it works again after make distclean, configure,
 make.
 > I already did `make distclean`.
 OK, now I did `make distclean`, `configure` and `make` on both Linux 32bit
 (Fedora 8) and Linux 64bit (Fedora 10) after svn up again. trunk works for
 me, display, query, rebuild topology, open vector with rebuilt topology in
 grass-6.4.0RC3, everything is fine. I used boundary_county of nc_spm_08.
 Segfault not reproducible by me, can someone else reproduce this?
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/536#comment:4>
