[GRASS-dev] Re: GRASS-dev] GRASS 6.4 Windows issues
Michael Barton michael.barton at asu.edu
Thu Mar 19 23:13:22 EDT 2009
On Mar 19, 2009, at 2:31 AM, <grass-dev-request at lists.osgeo.org> <grass-dev-request at lists.osgeo.org
 > wrote:
> From: Helmut Kudrnovsky <hellik at web.de>
> Date: March 18, 2009 1:52:58 PM GMT-07:00
> To: grass-dev at lists.osgeo.org
> Subject: [GRASS-dev] GRASS 6.4 Windows issues
>> In addition to the v.type.sh issue, there are at least 2 more places
>> where commands don't work in Windows.
>> v.patch won't start. Maybe it is not getting a bat version or
>> something?
>> v.rast.stats will not work because it calls another script
>> v.db.addcol
>> and calling a bash script from within a bash script in Windows seems
>> to be a problem.  (note that calling v.db.addcol from the tcltk
>> command processor works OK).
>> Can any of you windows folks check and find a way to fix these? I can
>> have people test in my lab.
>> Michael
> hi Michael,
> see also
> http://trac.osgeo.org/grass/ticket/488
> "v.db.addcol/v.rast.stats not working"
> best regards
> Helmut
Greetings Helmut,
This issue is similar but does not seem related, though it may be due
to the same underlying cause.
This is not a problem in specifying fields or the database. Rather the
error in v.rast.stats is that it cannot run v.db.addcol because the
file does not exist. However, v.db.addcol DOES exist and can be run
from either the console command line or the menus. There is something
in the script v.rast.stats that causes an error in windows when it
tries to run v.db.addcol.
I should note that this is under Vista.
We are having many problems still in running GRASS 6.4rc3 under Vista.
Michael
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090319/ed05133f/attachment.html
