[GRASS-dev] GRASS 6.4 Windows issues
Michael Barton michael.barton at asu.edu
Thu Mar 19 23:15:03 EDT 2009
I think that the reason that it works for you is that you is that you
built this on Vista. I'd bet that the OSGEO4W GRASS 6.4RC3 is built on
XP.
It looks like we need both XP and Vista versions unless the Vista
version works equally well on both.
Michael
On Mar 19, 2009, at 6:06 AM, Colin Nielsen wrote:
> Works for me (mingw/msys build on vista), v.patch and v.rast.stats all
> work in develbranch_6.
> However, they fail when tested on trunk.
> The v.patch window opens but then crashes when I run it.
> v.rast.stats gives this errror:
> Traceback (most recent call last):
>  File "C:\MinGW\msys\local\grass-7.0.svn\etc\wxpython\gui_m
> odules\mapdisp_window.py", line 536, in OnIdle
> self.UpdateMap(render=True)
> odules\mapdisp_window.py", line 661, in UpdateMap
> self.Draw(self.pdc, self.img, drawid=id)
> odules\mapdisp_window.py", line 289, in Draw
> pdc.DrawBitmap(bitmap, wx.Point(coords[0], coords[1]), True)
> # draw the composite map
>  File "c:\MinGW\Python\lib\site-packages\wx-2.8-msw-
> unicode\wx\_gdi.py", line 7438, in DrawBitmap
> return _gdi_.PseudoDC_DrawBitmap(*args, **kwargs)
> TypeError
> in method 'PseudoDC_DrawBitmap', expected argument 3 of type
> 'int'
>  File
> "C:/MinGW/msys/local/grass-7.0.svn/etc/wxpython/wxgui.py",
> line 521, in OnMenuCmd
> menuform.GUI().ParseCommand(cmd, parentframe=self)
> odules\menuform.py", line 1732, in ParseCommand
> xml.sax.parseString( getInterfaceDescription(cmd[0]),
> handler )
> odules\menuform.py", line 1673, in getInterfaceDescription
> raise IOError, _("Unable to fetch interface description for
> command '%s'.") % cmd
> IOError
> Unable to fetch interface description for command
> 'v.rast.stats'.
> -Colin
> On Wed, Mar 18, 2009 at 2:37 PM, Michael Barton <michael.barton at asu.edu
> > wrote:
>> In addition to the v.type.sh issue, there are at least 2 more
>> places where
>> commands don't work in Windows.
>> v.patch won't start. Maybe it is not getting a bat version or
>> something?
>> v.rast.stats will not work because it calls another script
>> v.db.addcol and
>> calling a bash script from within a bash script in Windows seems to
>> be a
>> problem.  (note that calling v.db.addcol from the tcltk command
>> processor
>> works OK).
>> Can any of you windows folks check and find a way to fix these? I
>> can have
>> people test in my lab.
>> Michael
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
