[GRASS-dev] Re: [GRASS GIS] #537: g.proj.exe crashes on Windows Vista (osgeo4w)
GRASS GIS trac at osgeo.org
Fri Mar 20 08:18:54 EDT 2009
  Reporter:  giohappy         |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  major            |   Milestone:  6.4.0
 Component:  default          |     Version:  6.4.0 RCs
Resolution:                   |    Keywords:  osgeo4w g.proj gdal
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by giohappy):
 In many forums I see similar problems with ntdll.dll, for various apps.
 One interesting explanation could be the following:
 ntdll is the user-mode entry into system services (that's "system calls"
 not process-based services). If a buggy app passes an invalid address to
 some ntdll entry point, the resulting exception will likely show an
 address in ntdll.
 you might see similar problems in many apps - there are many buggy apps
 out there.
Ticket URL: <http://trac.osgeo.org/grass/ticket/537#comment:1>
