[GRASS-dev] Re: lib/vector/Vlib/field.c: Assumes `HAVE_GDAL'
Ivan Shmakov oneingray at gmail.com
Mon Mar 23 23:10:23 EDT 2009
>>>>> Markus Neteler <neteler at osgeo.org> writes:
 >> Currently, GRASS doesn't compile well --without-gdal, since the
 >> code in `field.c' seems to assume that GDAL is available.
 >> The following patch seems to fix the issue.  Unless there'll be
 >> objections, I'm going to commit it to the trunk.
 >> --- field.c (revision 36440)
 >> +++ field.c (working copy)
 >> @@ -29,7 +29,9 @@
 >>  #include <grass/dbmi.h>
 >>  #include <grass/Vect.h>
 >> +#ifdef HAVE_GDAL
 >>  #include <gdal_version.h> /* needed for FID detection */
 >> +#endif /* HAVE_GDAL */
 > This looks good to me (untested).
	At least, it compiles here (without HAVE_GDAL) fine.
	I've committed the change as r36464.
http://trac.osgeo.org/grass/changeset/36464
FSF associate member #7257
