[GRASS-dev] Re: v.in.gshhs - bogus horizontal lines
Maciej Sieczka msieczka at sieczka.org
Tue Mar 24 15:38:45 EDT 2009
Markus Metz pisze:
> Maciej Sieczka wrote:
>> Markus Metz pisze:
>>> That would be the fool proof solution to avoid horizontal lines. But
>>>  then you have vertical lines...
>> If you decide it's worth your time to provide that *as an option* in
>> v.in.gshhs it'd be cool.
> Not right now, first I want to get grass7 topology substantially faster
> than grass6 topology, then I want to check an idea on how to make
> r.watershed in segmented mode faster (than r.terraflow), and then I
> could look at grass-addons modules. v.in.gshhs is currently very low on
> my priority list, and this suggested change is time consuming to implement.
I'm really excited about your present and upcoming vector-related
improvements. You are doing an extremely important job.
Regards,
Maciek
Maciej Sieczka
http://www.sieczka.org
