[GRASS-dev] Re: [GRASS GIS] #520: r.terraflow/iostream does not respect STREAM_DIR option
GRASS GIS trac at osgeo.org
Tue Mar 24 21:36:45 EDT 2009
  Reporter:  mmetz   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  major   |   Milestone:  6.4.0
 Component:  Raster  |     Version:  svn-develbranch6
Resolution:          |    Keywords:
  Platform:  All     |         Cpu:  All
Comment (by glynn):
 Replying to [comment:2 neteler]:
 > attached patch uses dirname(G_tempfile()) to create tmp dir in mapset
 instead of /var/tmp/.
 It should use either the directory specified by the stream_dir= option or
 $TMPDIR, so that the user can choose a directory on a partition which has
 enough space.
Ticket URL: <http://trac.osgeo.org/grass/ticket/520#comment:3>
