[GRASS-dev] db.connect
Marco Lechner - FOSSGIS e.V. marco.lechner at fossgis.de
Wed Mar 25 17:12:18 EDT 2009
or: with db.connect (QGIS-Version) you can't use the optional parameter
schema. If you want to connect to a database providing schemas you have
to use db.connect.schema
I guess the db.connect Version of QGIS is just for not "bothering"
normal users who don't know about schemas ;-)
Marco
Markus Neteler schrieb:
> On Wed, Mar 25, 2009 at 4:29 PM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
>> On 24/03/09 10:46, Paolo Cavallini wrote:
>>> Hi all.
>>> Sorry about my ignorance. I do not understand why having both db.connect
>>> and db.connect.schema (the second is == to the first, with just one
>>> extra option).
>> Where do you see a db.connect.schema ? db.connect has a schema option.
> I see in the QGIS source code:
> cat src/plugins/grass/modules/db.connect.qgm
> <?xml version="1.0" encoding="UTF-8"?>
> <!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
> <qgisgrassmodule label="Set general DB connection" module="db.connect">
>         <option key="driver" answer="dbf" hidden="no"/>
>         <option key="database"
> answer="$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/" hidden="no"/>
> </qgisgrassmodule>
> cat src/plugins/grass/modules/db.connect.schema.qgm
> <qgisgrassmodule label="Set general DB connection with a schema"
>         <option key="schema" answer=" " hidden="no"/>
> </qgisgrassmodule>
> To me it looks like a replication since the schema answer isn't predefined.
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
