[GRASS-dev] Re: [GRASS-windows] windows qgis-grass: make grass build with vc or keep a separate qgis-grass mingw build?
Jürgen E. Fischer jef at norbit.de
Thu Mar 26 14:05:45 EDT 2009
Hi Markus,
On Thu, 26. Mar 2009 at 12:51:09 +0100, Markus Neteler wrote:
> On Thu, Mar 26, 2009 at 11:23 AM, G. Allegri <giohappy at gmail.com> wrote:
> >  2 - Others are proposing to make a deep refactoring of grass code to
> > make it buildable with vc.
> could you elaborate on that? What's needed, what's missing in terms
> of *deep refactoring*?
If you try to compile GRASS code with MSVC you'll run into a number of
issues.  Most, if not all, are easy to fix.   Nothing "deep".  I did
compile some of the GRASS libraries with MSVC for QGIS at some point,
submitted patches and Glynn applied them.
But at long as we use only use C and not C++ there's just the issue of
malloc()/free() across DLL boundaries, that is an issue, if you mix
MinGW and VC built code.   I'd consider those bugs - although it's
probably harmless on platforms other than Windows.
FMPOV the build system is the real issue not the codebase.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
