[GRASS-dev] Re: [GRASS-windows] windows qgis-grass: make grass build with vc or keep a separate qgis-grass mingw build?
Jürgen E. Fischer jef at norbit.de
Thu Mar 26 16:43:12 EDT 2009
Hi Glynn,
On Thu, 26. Mar 2009 at 18:44:32 +0000, Glynn Clements wrote:
> > FMPOV the build system is the real issue not the codebase.
> The build system is a non-issue, as it doesn't affect the resulting
> binaries.
Sorry, I don't see what's your point is here.
> Maintaining DSW/DSP files (or nmake files) isn't a realistic option,
> and anything else will be "foreign" on Windows.
cmake would work both ways.  It can produce Makefiles and MSVC projects
(nmake or DSW/DSP/SLN/vcproj).
My point was simply, that if GRASS were to use cmake instead of
configure/make most part of making that happen would be on the build
system and not on the codebase itself.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
