[GRASS-dev] Re: [GRASS-windows] windows qgis-grass: make grass build with vc or keep a separate qgis-grass mingw build?
G. Allegri giohappy at gmail.com
Fri Mar 27 07:16:21 EDT 2009
Ok Markus. I'm sorry for pressing... My hope is to do not have a
broken community around this issues. I would like to come to a common
thought, and work for a coherent and clear roadmap. Probably it's me
(and the users) that don't have it clear, while it is for all of the
developers: who is doing what and in which direction?
>From an old Qgis log, Frank has explained that his dream is to have
everything coherently packaged under osgeo4w, and hopefully to be able
to extract standalone builds from it  (ie, qgis, grass, qgis+grass).
This viewsight probably would be the best from the users point of
view. The best would be to have osgeo4w setup, and standalone NSI
installers... but I'm talking with no experience on what this would
require, or if it's possible.
I hope the discussion will go on.
2009/3/27 Moritz Lennert <mlennert at club.worldonline.be>:
> On 27/03/09 10:30, G. Allegri wrote:
>  >  In any case the questions remain:
>>  1 -  continue to build grass with MingW?
>>      1a: build it against MinGW built libs (not osgeo4w)?
>>      1b: build it against vc built libs (osgeo4w)?
>> 2 - build Qgis with vc (osgeo4w) and solve the bindings problems with
>> Grass: 1a or 1b?
> IIUC what Markus and Glynn are trying to get at: these questions seem to be
> a bit quick without having clarified where the problem actually lies. Is it
> with the GRASS source code, is it with the choice of build system or is it
> with the osgeo4w tool chain. Jürgen says it's mainly the choice of
> configure/make which is at stake, Glynn seems to contest that. So before we
> haven't clearly identified where the problems actually lie, we cannot answer
> the above questions.
> Moritz
