[GRASS-dev] Re: [GRASS GIS] #536: memory corruption
GRASS GIS trac at osgeo.org
Sat Mar 28 13:35:55 EDT 2009
  Reporter:  martinl  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  7.0.0
 Component:  Vector   |     Version:  svn-trunk
Resolution:  fixed    |    Keywords:
  Platform:  Linux    |         Cpu:  x86-32
Changes (by martinl):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:14 mmetz]:
 > Can you try the first patch, and if that doesn't work, the second patch?
 > I seems that v.info failed in main.c:334
 > My guess is that the real problem is in v.info main.c:112. It would be
 safer if v_head would be a pointer and line 112 would be v_head =
 &Map.head. Even better is patch1, if it works for you.
 > Hope that helps.
 Right, it helps (committed in r36508). Anyway I do not understand why
 memory corruption was detected only in GRASS7 not GRASS6.
Ticket URL: <http://trac.osgeo.org/grass/ticket/536#comment:15>
