[GRASS-dev] [GRASS GIS] #540: wxGUI - Map Display only in the task bar
GRASS GIS trac at osgeo.org
Sun Mar 29 06:10:06 EDT 2009
 Reporter:  hellik            |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect            |      Status:  new
 Priority:  major             |   Milestone:  6.5.0
Component:  wxGUI             |     Version:  svn-develbranch6
 Keywords:  wx-GUI, task bar  |    Platform:  MSWindows Vista
      Cpu:  Unspecified       |
 GRASS-devel6, build from source rev. 36355
 the starting window is ok, i can choose the nc-dataset
 the Layer Manager appears normally, but the Map display is only in the
 task bar
 and the following erros message:
   File "c:\OSGeo4W\apps\grass\grass-6.5.svn\etc\wxpython\gui
 _modules\mapdisp_window.py", line 536, in OnIdle
 self.UpdateMap(render=True)
 _modules\mapdisp_window.py", line 635, in UpdateMap
 windres=windres)
 _modules\render.py", line 915, in Render
 os.environ["GRASS_REGION"] = self.SetRegion(windres)
 _modules\render.py", line 717, in SetRegion
 region = self.AdjustRegion()
 _modules\render.py", line 504, in AdjustRegion
 self.region["nsres"] =  mapheight / self.height
 ZeroDivisionError
 float division
 if i do the same action in osgeo4w-GRASS64-rc, everything is ok.
 best regards
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/540>
