[GRASS-dev] GRASS 7 configure fails on Mac
Martin Landa landa.martin at gmail.com
Mon Mar 30 14:38:56 EDT 2009
2009/3/30 Michael Barton <michael.barton at asu.edu>:
> I just did an svn update from trunk and tried to configure GRASS 7 prior to
> compiling. I'm using the same configure string that worked successfully 48
> hours ago. But configure failed with an geos-config error (below). Is this a
> bug, or do I need to change my config string to something different?
recently geos supported was added, so you need to install GEOS library
or configure with --with-geos=no.
M.
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
