[GRASS-dev] GRASS 7 configure fails on Mac
Michael Barton michael.barton at asu.edu
Mon Mar 30 17:25:41 EDT 2009
On Mar 30, 2009, at 11:38 AM, Martin Landa wrote:
> Hi,
> 2009/3/30 Michael Barton <michael.barton at asu.edu>:
>> I just did an svn update from trunk and tried to configure GRASS 7
>> prior to
>> compiling. I'm using the same configure string that worked
>> successfully 48
>> hours ago. But configure failed with an geos-config error (below).
>> Is this a
>> bug, or do I need to change my config string to something different?
> recently geos supported was added, so you need to install GEOS library
> or configure with --with-geos=no.
> M.
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
This doesn't work either, nor does --without-geos.
There seems to be something broken here.
Michael
