[GRASS-dev] GRASS 7 configure fails on Mac
William Kyngesburye
woklist at kyngchaos.com
Mon Mar 30 18:24:26 EDT 2009
On Mar 30, 2009, at 4:57 PM, Martin Landa wrote:
>> Is GEOS support really using the C++ API? geos-config --libs only
>> returns
>> the C++ linking info.
> No, C API.
Then add -lgeos_c the GEOS_LIBS? Though you might want an extra check
to verify libgeos_c exists.
Maybe this is where Michael is having problems.
>> Searching the rest of the source, I don't see GEOS used, yet, so
>> there
>> should be no problems compiling --without-geos. Is this yet to come?
> lib/vector/Vlib/geos.c
> vector/v.select/geos.c
Strange, my text search for GEOSLIBS and GEOSCLFAGS didn't turn up
anything (except in configure where I looked with my eyes), yet I see
them in platform.make.in, grass.make and vlib/makefile. Must have had
a filter on.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
