[GRASS-dev] GRASS 7 configure fails on Mac
Martin Landa landa.martin at gmail.com
Tue Mar 31 01:03:15 EDT 2009
I will put checking for geos_c.h to configure. M.
2009/3/31 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2009/3/31 Michael Barton <michael.barton at asu.edu>:
>> So you're saying that vdigit doesn't work again because of the geos problem?
> again, problem? ;-)
> I wasn't expecting that if you have GEOS installed that geos_c.h is
> not available. If so than vector libs compilation fail. In this case
> checking for geos-config is not enough.
> M.
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
