[GRASS-dev] Problem v.in.ascii (GRASS6.4.0RC4)
roberto marzocchi roberto.marzocchi at gmail.com
Wed May 6 03:02:44 EDT 2009
Ok, without white space the command run correctly.
Grass 6.4 and 6.5 "don't like" white space in a character string.
No problem with * character!
Many thanks
Roberto
2009/5/5 Markus Neteler <neteler a osgeo.org>
> Hi Roberto,
> I can reproduce the problem:
> GRASS 6.5.svn (spearfish60):/tmp > v.in.ascii -z input=profilo_30.txt
> output=name_output format=point fs=" "  skip=0 x=1 y=2 z=3 cat=0
> Scanning input for column types...
> Maximum input row length: 35
> Maximum number of columns: 10
> Minimum number of columns: 4
> Importing points...
>  100%
> Populating table...
> dbmi: Protocol error
> No good.
> GRASS 6.5.svn (spearfish60):/tmp > g.gisenv set=DEBUG=3
> output=name_output format=point fs=" "  skip=0 x=1 y=2 z=3 cat=0 --o
> D2/3: Vect_open_new(): name = name_output
> D2/3: load_table_head(): tab = 30,
> /home/neteler/grassdata/spearfish60/neteler/dbf//name_output.dbf
> D3/3: Doing SQL command <3> on DBF table... (see include/sqlp.h)
> D2/3: load_table(): tab = 30
>  100%
> Populating table...
> D2/3: Commit transaction
> D2/3: save_table 27
> D2/3: save_table 28
> D2/3: save_table 29
> D2/3: save_table 30
> D2/3: Write table to tempfile:
> '/home/neteler/grassdata/spearfish60/neteler/.tmp/host550/17010.dbf'
> D2/3: Write 108 rows
> D3/3: Vect_build(): build = 4
> Building topology for vector map <name_output>
> The file /home/neteler/grassdata/spearfish60/neteler/.tmp/host550/17010.dbf
> is only of
> 1 byte size, so corrupted.
> Using the SQLite driver, I get a more useful error message:
> DBMI-SQLite driver error:
> Error in sqlite3_prepare():
> table name_output has 11 columns but 10 values were supplied
> D2/3: G__home home = /home/neteler
> ERROR: Unable to insert new record: insert into name_output values ( 1,
>       715514.14, 93561.67, 304.19, '53', null, null, null, null, null)
> As we see: 5 empty columns are recognized.
> This is because there are white spaces at the end of the first row,
> maybe elsewhere, too.
> So: GRASS is working but the error trapping in the DBF driver isn't
> that good (the SQLite driver is better here).
> Solution: polish the data file...
> Markus
> PS: the * in some rows will also cause problems.
> On Tue, May 5, 2009 at 10:55 PM, roberto.marzocchi
> <roberto.marzocchi a gmail.com> wrote:
> > I have the same problem in the command line (using fs='  ') and using the
> > GUI without quoting
> > maybe i have a problem with libraries....?
> > R
> > Moritz Lennert ha scritto:
> >> On 05/05/09 17:45, roberto marzocchi wrote:
> >>> in attached the input file
> >>> in grass6.3.0 the command run, the problem is only with the last grass
> >>> version
> >> Have you tried quoting the fs, i.e.:
> >> v.in.ascii -z input=fle_input  output=name_output format=point fs=' '
> >> skip=0 x=1 y=2 z=3 cat=0 --overwrite
> >> Running it without quoting, I get:
> >> ERROR: y column number > minimum last column number
> >>       (incorrect field separator?)
> >> With quoting it works (in the grass6 development branch).
> >> How are you running this command ? On the command line ? In the GUI ?
> >> Moritz
> >>> R
> >>> 2009/5/5 Moritz Lennert <mlennert a club.worldonline.be
> >>> <mailto:mlennert a club.worldonline.be>>
> >>>        fs=  skip=0 x=1 y=2 z=3 cat=0 --overwrite --quiet
> >>>        Output:
> >>>        Segmentation fault
> >>>        Grass import correctly the points, but don't create the
> >>>        associated table. anyone know the reason?
> >>>    Is there any attribute data contained in the input file ? It would
> >>>    help if you sent us at least the first few lines of the data.
> >>>    Also fs= seems weird. What is the field separator in the file ?
> >>>    Moritz
> >>> Please consider the environment before printing this mail note!
> > grass-dev mailing list
> > grass-dev a lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
Roberto Marzocchi
SUPSI-Istituto scienze della terra -Institute of Earth Sciences
Via Trevano C.P. 72 6952 Canobbio  Switzerland
Phone: +41 58 6666 212
Fax: +41 58 6666 209
E-mail: roberto.marzocchi a supsi.ch
Internet: www.ist.supsi.ch
Un allegato HTML ? stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090506/43f2fb71/attachment-0001.html
