[GRASS-dev] Re: [GRASS GIS] #577: v.in.ogr: imported GPX file results in N=0, W=0
GRASS GIS trac at osgeo.org
Wed May 6 12:07:50 EDT 2009
  Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  normal  |   Milestone:  6.4.0
 Component:  Vector  |     Version:  svn-develbranch6
Resolution:          |    Keywords:  v.in.ogr, gpx
  Platform:  Linux   |         Cpu:  x86-32
Comment (by mmetz):
 This empty track makes its way into the grass vector as an empty feature
 (primitive with no vertices). This should not happen because the vector
 libraries can't handle empty features. Could be fixed either in v.in.ogr
 or in the vector libraries, i.e. in Vect_write_line().
Ticket URL: <https://trac.osgeo.org/grass/ticket/577#comment:8>
