[GRASS-dev] Re: [GRASS GIS] #587: WinGRASS: can't open a map for wxDigitizing
GRASS GIS trac at osgeo.org
Thu May 7 10:24:00 EDT 2009
  Reporter:  hamish        |       Owner:  martinl
      Type:  defect        |      Status:  closed
  Priority:  major         |   Milestone:  6.4.0
 Component:  wxGUI         |     Version:  6.4.0 RCs
Resolution:  duplicate     |    Keywords:  wingrass digitize
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:9 hamish]:
 > > Converting it into the desired format will require some
 > > processing commands in configure.in or the Makefiles.
 > .... such as | cut -f2 -d'$' ? or do you mean date string format?
 I mean for any format other than the one SVN uses for $Date$.
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:10>
