[GRASS-dev] [GRASS GIS] #592: wxGUI: allow location wizard to set DMS bounds
GRASS GIS trac at osgeo.org
Thu May 7 10:49:38 EDT 2009
 Reporter:  hamish           |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement      |      Status:  new
 Priority:  normal           |   Milestone:  6.4.0
Component:  wxGUI            |     Version:  6.4.0 RCs
 Keywords:  location wizard  |    Platform:  All
      Cpu:  All              |
 it would be nice if the location wizard would accept DDD:MM:SS.SSh style
 string input like g.region accepts. currently only numeric values are
 allowed.
 more advanced idea: it could detect if the location is lat/lon or not and
 switch to another style with three stacked boxes for D M S values and
 radio buttons for N/S, E/W. all three D M S should accept decimal values
 and all but D should start empty, not as 0.0.
 a negative value for degree would automatically override the radio button.
 so the same as g.region (except pad out %02d minutes and sec as needed)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/592>
