[GRASS-dev] Re: [GRASS GIS] #587: WinGRASS: can't open a map for wxDigitizing
GRASS GIS trac at osgeo.org
Fri May 8 05:44:10 EDT 2009
  Reporter:  hamish        |       Owner:  martinl
      Type:  defect        |      Status:  closed
  Priority:  major         |   Milestone:  6.4.0
 Component:  wxGUI         |     Version:  6.4.0 RCs
Resolution:  duplicate     |    Keywords:  wingrass digitize
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hamish):
 Replying to [comment:11 martinl]:
  #define GIS_H_DATE "$Date$"
 > done in r37043.
 any objections to backporting this?
 > The patch for g.version attached (comments?)
  * keep it easily parsable (on one line), and as backwards compatible as
 possible for existing script parsing.
  * (for grass 7 only) s/GRASS/GRASS GIS/
  * flags for diff't info? (only if needed)
  * modify doc/howto_release.txt to say that GRASS_VERSION_DATE should be
 manually set to the release day for official releases, and for SVN builds
 take it from GIS_H_DATE?
  * append the numeric value portion of GIS_H_VERSION (ie rev #) to
 GRASS_VERSION_NUMBER in the g.version output if 'svn' is found in
 GRASS_VERSION_NUMBER. so it automatically looks like "6.4.0svn32001"
 This way it could be backwards compatible for g6 script parsing.
  * is GRASS_VERSION_UPDATE_PKG relevant anymore for grass >= 5?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:12>
