[GRASS-dev] Re: [GRASS GIS] #570: startup problem with standalone GRASS install
Martin Landa landa.martin at gmail.com
Sat May 9 08:25:13 EDT 2009
2009/5/9 Glynn Clements <glynn at gclements.plus.com>:
>> > OK, done in r37060.
>> Er, I think I misread "python-config" as "wx-config".
>> While this change is reasonable enough in itself,
> Actually, I take that back. The SWIG wrappers need PYTHON_CFLAGS etc,
> so configure should generate a fatal error if --with-python is given
> but python-config can't be found. Either that, or configure needs to
> get this information from setup.py.
Probably SWIG wrappers should be also build with setup.py...
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
