[GRASS-dev] python grass problems on OSX (Incompatible library version for module)
massimo di stefano massimodisasha at yahoo.it
Mon May 11 02:39:55 EDT 2009
Il giorno 11/mag/09, alle ore 08:21, Hamish ha scritto:
> massimo wrote:
>> I removed the graas_trunk source code and re-download a new
>> one and rebuild it using these configure [1]
>> but the problem persists.
> what's OSX's version of ldd called?
> if you run that within the broken environment it will tell you which
> libraries it is trying to use.
> Hamish
Hamish, sorry i can't undstand well the question :-( ,
"what's OSX's version of ldd"   <<  i don't know how to retrieve thise
information,  how can i have  infos about a broken environment and which
libraries it is trying to use. ?
p.s..
I'm on osx 10.5.6,
firsto to run make i export the environment :
export CXXFLAGS="-arch ppc -arch i386 -Os" ; export CFLAGS="-arch ppc -
arch i386 -Os" ; export LDFLAGS="-arch ppc -arch i386 -Os" ; export
GDAL_BIN=/Library/Frameworks/gdal.framework/unix/bin/ ; export
NAD2BIN=/Library/Frameworks/PROJ.framework/Programs/nad2bin
while these are my $PATH vars :
macbook-pro-15-di-sasha:~ sasha$ echo $PATH
/Library/Frameworks/GDAL.framework/Programs:/usr/local/pgsql/bin:/
Library/Frameworks/FFTW3.framework/Programs:/Library/Frameworks/
SQLite3.framework/Programs:/Library/Frameworks/PROJ.framework/
Programs:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/texbin:/usr/
X11/bin:/usr/local/git/bin
Massimo Di Stefano
massimodisasha a yahoo.it
epifanio on   irc.freenode.net  /join gfoss
Chiacchiera con i tuoi amici in tempo reale!
 http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
