[GRASS-dev] v.out.ogr patch: support OGR "update"
Benjamin Ducke benjamin.ducke at oxfordarch.co.uk
Mon May 11 06:27:02 EDT 2009
The patch I just sent was slightly faulty in that it always produced
a warning about ignoring OGR dsco parameters in update mode even when
none were given. Sorry about that. Attached is a fixed version.
I have run some tests with a PostGIS database and that seemed to work
just fine (adding new layers as tables to an existing DB), so this
is an SQLite issue. However, since ogr2ogr manages to stuff features
into an SQLite DB just fine, there must be something wrong with
either the GRASS interface or my own installation.
Maybe someone else could do some quick SQLite testing just to
confirm I am not the only one for who things don't work?
That would make it much easier for me to narrow down the problem.
Thanks,
Ben
Benjamin Ducke wrote:
> Dear all,
> I have attached a very small patch to v.out.org against the
> version in 6.4.SVN. It adds a "-u" flag that allows users
> to update data in existing OGR sources. It's the same as
> ogr2ogr's "-update" option and _very_ important for being able
> to write layers as tables into existing spatial databases.
> It should not be able to break any existing functionality.
> If a data source does not support updates (like Shapefiles),
> then Ogr_Dr_open() behaves the same as Ogr_Dr_CreateDataSource().
> Despite the update, I have not been able to successfully
> write OGR features to an existing (or new) SQLite DB.
> OGR_L_CreateFeature() results in this error from the SQLite driver
> after the first feature has been written:
> ERROR 1: sqlite3_step() failed:
>   SQL logic error or missing database
> Strangely, the first feature is written into the table just fine,
> but the error appears for all consecutive writes.
> I will have to do more tests to see if this is an SQLite
> and GRASS specific problem (ogr2ogr works fine).
> Cheers,
> Ben
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Benjamin Ducke
Senior Geospatial Consultant
Oxford Archaeology
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090511/27cfb228/v.out.ogr-0001.bin
