[GRASS-dev] [GRASS GIS] #600: d.vect: add new size_column=, rotation_column= options
Moritz Lennert mlennert at club.worldonline.be
Wed May 13 03:16:31 EDT 2009
>  Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
>      Type:  enhancement  |      Status:  new
>  Priority:  normal       |   Milestone:  6.5.0
> Component:  Vector       |     Version:  svn-develbranch6
>  Keywords:  d.vect       |    Platform:  All
>       Cpu:  All          |
>  Hi,
>  it would be nice if d.vect had two new options for display of
>  points/icons: size_column= and rotation_column=.
>  I think to do it we'd just have to clone the code from the existing
>  rgb_column=, wcolumn= options, then:  (as in d.graph)
Or use the code for size_column in d.vect.chart
Moritz
