[GRASS-dev] Error on attempted read access to a vector map in PERMANENT
Benjamin Ducke benjamin.ducke at oxfordarch.co.uk
Wed May 13 09:13:07 EDT 2009
OK, that clarifies it!
Thanks,
Ben
Markus Neteler wrote:
> On Wed, May 13, 2009 at 2:05 PM, Benjamin Ducke
> <benjamin.ducke at oxfordarch.co.uk> wrote:
>> Dear all,
>> I just came across an issue with vector maps in the PERMANENT mapset
>> and was wondering if anyone else had the same problem.
>> Whenever I want to get read access to a DBF attribute table for
>> a vector file in PERMANENT (while logged into a user mapset),
> ... to my knowledge, you cannot with the db.* modules.
> That's why the v.db.* modules exist, those work also cross-mapset.
> I suggest to update the related document(s), e.g.  [1].
> Hope this (somewhat) helps,
> Markus
> [1] http://grass.osgeo.org/grass65/manuals/html65_user/databaseintro.html
Benjamin Ducke
Senior Geospatial Consultant
Oxford Archaeology
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
