[GRASS-dev] [GRASS GIS] #603: r.neighbors with an output reference map
GRASS GIS trac at osgeo.org
Wed May 13 18:31:32 EDT 2009
 Reporter:  frankie      |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.0
Component:  default      |     Version:  6.4.0 RCs
 Keywords:               |    Platform:  All
      Cpu:  Unspecified  |
 If r.neighbours accepted a reference mask to compute convolution only on
 non masked points, it could reduce significantly computing time on large
 datasets and/or large window sizes. Of course that could be done after the
 whole map computation, but computing time would change significantly.
 Note that this is different from having an ordinary MASK applied to the
 input map, because the input raster is not masked out at all at
 convolution time.
Ticket URL: <http://trac.osgeo.org/grass/ticket/603>
