[GRASS-dev] Re: [GRASS GIS] #604: /usr/lib/grass64/etc/grass-run.sh does not work properly when called by gis.m to execute in a external xterm
GRASS GIS trac at osgeo.org
Thu May 14 23:37:33 EDT 2009
  Reporter:  frankie   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  Tcl       |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  xterm
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by hamish):
 Replying to [comment:4 hamish]:
 > not sure how to fix it in sh
 this patch seems to work:
 Index: lib/init/grass-run.src
 --- lib/init/grass-run.src      (revision 37238)
 +++ lib/init/grass-run.src      (working copy)
 @@ -26,7 +26,7 @@
  echo
  # run command
 +eval "$@"
  EXIT_VAL=$?
  if [ $EXIT_VAL -ne 0 ] ; then
 `exec` is no good because it takes over control from the script.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/604#comment:5>
