[GRASS-dev] Re: [GRASS GIS] #561: meta: add a new "normal" bug priority
GRASS GIS trac at osgeo.org
Fri May 15 03:37:13 EDT 2009
  Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  closed
  Priority:  minor        |   Milestone:  Website
 Component:  Website      |     Version:
Resolution:  fixed        |    Keywords:  trac
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by hamish):
 Replying to [comment:3 neteler]:
 > re "all tickets modified in the last week":
 > The "Active ticket" code is
  SELECT p.value AS __color__,
 ... a rather impressive bit of SQL follows ...
 > re "open tickets reported by me" - likewise.
 AFAIK that can be simply built with existing menus into:
 http://trac.osgeo.org/grass/query?status=new&status=assigned&status=reopened&reporter=$OSGEOID
 or do those reports require direct SQL into the DB?
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/561#comment:4>
