[GRASS-dev] Re: [GRASS GIS] #604: /usr/lib/grass64/etc/grass-run.sh does not work properly when called by gis.m to execute in a external xterm
GRASS GIS trac at osgeo.org
Fri May 15 23:57:18 EDT 2009
  Reporter:  frankie   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  Tcl       |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  xterm
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by hamish):
 Replying to [comment:7 glynn]:
 > Replying to [comment:5 hamish]:
 > > > not sure how to fix it in sh
 > > this patch seems to work:
  +eval "$@"
 > This is bogus; it will cause the argument list to be re-parsed.
 do you have a better suggestion then? That's the best I got.
 FWIW the above successfully runs this via "Run in Xterm":
  v.db.select roads where="label ~ 'highway'"
 (set DEBUG=1 to avoid window closing after completion; but then debug
 level 1 is somewhat overused so many messages to sort through)
 with the above patch what's a case that fails?
 at leaast it's a step up from the last version which wouldn't run anything
 with arguments at all.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/604#comment:9>
