[GRASS-dev] Re: GEOS support in GRASS 6.5 ?
Martin Landa landa.martin at gmail.com
Mon May 18 12:33:17 EDT 2009
2009/5/15 Moritz Lennert <mlennert at club.worldonline.be>:
> I can't find your mail announcing the inclusion of advanced GEOS operators
> in v.select, but I have to say that I really think that this is an important
> improvement. Any reason that this shouldn't be backported to 6.5 ?
no special reason here, the GEOS support is just very initial and
untested. Moreover vector features are read to line_pnts structure,
i.e. instance of GEOS geometry class is created based on the line_pnts
which quite slow for large vector data layers. Data should be read
directly.
Anyway if you think it should be backported to devbr6, I have no objections.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
