[GRASS-dev] Change in parser behavior?
Michael Barton Michael.Barton at asu.edu
Wed May 20 02:33:15 EDT 2009
Hamish
It *looks* like changing all options to lower case fixed this. It is
NOT an r.terraflow issue because the options are not getting parsed
before they ever get to r.terraflow.
Do you know when this happened? Your email posting was in April of
this year. It is important to find out when this stopped working for a
paper Isaac, Helena, and I are about to send in.
BTW, all the grass trac addresses (ttp://trac.osgeo.org/grass and the
like) produce an Internal Server Error. Is the GRASS trac site out?
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On May 19, 2009, at 7:04 PM, Hamish wrote:
> Hamish wrote:
>> since a while ago the parser has not liked option names with
>> upper case characters. e.g. STREAM_DIR= in r.terraflow. I think
>> there was some posts about it, you were not the only person to
>> have trouble with addon scripts.
>> try changing to r= k= c= and I'm guessing it should work.
>> why? I've got no idea & it should probably be fixed before
>> 6.4.0 as it (case in point) breaks back-compatibility even if
>> none of the standard GRASS modules use it. It is my guess that
>> currently r.terraflow will have issues because of it.
> refs:
> http://thread.gmane.org/gmane.comp.gis.grass.devel/32805/focus=32811
> http://trac.osgeo.org/grass/ticket/520  (open bug)
> Hamish
