[GRASS-dev] r.mapcalc: verbose output for eval() function?
Tue May 26 20:38:29 EDT 2009
Markus Neteler wrote:
> I am trying to see if an eval() function in my r.mapcalc script
> does what it should. Is there a way to activate a "verbose"
> mode which spits out for each pixel operation the values of
> the used variables?
> Using 'sh -x' isn't sufficient for variables declared within r.mapcalc...
Use gdb.
